Terumo - Sarns System 1
by Terumo
Heart-Lung Bypass Unit
Terumo System 1's design allows the extracorporeal blood circuit to be positioned closer to the patient. The central control monitor not only displays information but also serves as a controller allowing the perfusionist to operate the system from a location further away.
FORUMSView All (3)
-elmejd
Fri Apr 26 2019
system1
We have a problem with the machine terumo system 1 It does not work on the sector. It's only the battery that keeps the machine on. When the battery is exhausted, it can not be turned on againReply
-elmejd
Thu Apr 25 2019
monitor
the monitor requests the calibration and it is blockedReply
4
-zrgllc
Sat Nov 19 2016
Screen calibration
Hello everyone,
Does anyone know how to calibrate the touch screen on the Terumo System 1?  My unit makes it impossible to touch the icons on the bottom of the screen as the cursor won't go that far down on the screen when you touch the very bottom.
Thanks in advance!
  • Compact base with choice of brackets and holders
  • System design allows users to define safety and pump responses
  • Standard and advanced multiple cardioplegia delivery options
  • Central Control Monitor with fast processing and a high-resolution screen
  • Pole-mounted pumps
  • Integrated gas blender
Height22.6 in
Length 35.2 in
Weight262 lbs
Width26.6 in
