Terumo - Sarns 9000
by Terumo
Heart-Lung Bypass Unit
The Sarns 9000 is a computerized heart lung machine that is available in a variety of configurations. The Terumo Sarns 9000 is used in extracorporeal circulation of blood for arterial perfusion, regional perfusion, and cardiopulmonary bypass procedures. With occluder installed in the Sarns 9000, the operator can rapidly or gradually adjust the blood flow of the venous line. The Sarns 9000 has a backup battery pack that is constantly being charged when the system is in operation. If AC power failure occurs, the battery backup will automatically supply power to the system. When adding the option to install the water mixing system, hot and cold water form a wall supply is mixed for use with cardioplegia and arterial heat exchangers. This water mixing system allows you to lower and raise the patient's temperature as needed.
1ReplyThu Sep 26 2024 | User Manual I need a user manual for a Sarns 9000 Equipment: Terumo - Sarns 9000 Reply |
1ReplyWed Jun 22 2016 | SARNS 9000 I havea SARNS 9000 heart lung machine and a broken screen monitor Where cand I send it to get it fixed or where to buy a refurbished one? Reply |
2RepliesMon Feb 10 2014 | user manuel
I need user manuel for the Terumo Sarns 9000 heart lung machine. Thanks Reply |
| Height | 25.3 in Console |
| Length | 24 in Console |
| Weight | 31 lbs Console |
| Width | 45.3 in Console |
Centrifugal PumpDisplay
