SciCan - BRAVO
Chamber autoclaveThe BRAVO fractionated vacuum chamber autoclave continues the SciCan tradition of being at the forefront of innovation and technology. BRAVO incorporates both pre-vac (to remove air) and post-vac (to help drying) cycles to ensure perfect steam penetration for any load. BRAVO is true to the STATIM reputation for speed, providing rapid cycles for all types of instrument loads.
FORUMSView All (4)
1Replya year ago | fuse blow why fuse blow Equipment: SciCan - BRAVO Reply |
0Replies3 years ago | The door wont close The door to the bravo autoclave is not able to be closed. What should we do?Reply |
0Replies11 years ago | BRAVO fractionated chamber autoclave, from SciCan The BRAVO line of chamber autoclaves is one of the fastest on the market today. BRAVO offers a perfect blend of speed and chamber capacity coupled with our drying technology to ensure your daily output of reprocessed instruments cannot be rivaled. Reply |
VIDEOS
[list] [*] Speed - The BRAVO line of chamber autoclaves is one of the fastest on the market today. BRAVO offers a perfect blend of speed and chamber capacity coupled with our drying technology to ensure your daily output of reprocessed instruments can not be rivaled. [*] Dryness - With closed door drying and the Dri-Tec drying system, the BRAVO gives you lightning fast & consistent dry loads every time to allow more loads to be processed daily. [*] Versatility - The BRAVO offers numeroussterilization cycles with a wide array of parameters. This allows the user to choose the appropriate cycle for the load, be it wrapped or unwrapped. [*] Ease of use - The BRAVO can be initiated by a single button. Once the BRAVO has been properly loaded, the user can choose from one of four pre-set cycles as defined by the user. [/list]
Chamber Volume | 21 L |
Orientation | Benchtop |
Power Requirements | 120 VAC |
Weight | 139 lbs |
