Drucker Diagnostics - 642VES
by Drucker Diagnostics
Use the 642VES for a variety of tests ranging from urine and fertility testing up to blood separations and more.
It holds six (6) test tubes up to 10mL (up to 17mm x 100mm) and includes a "0" RPM safety lid lock. A wide variety of optional accessories are available to customize your centrifuge.
-me_samm
Fri Mar 01 2024
Can't Gain Speed Error
"Can't gain speed" error occurs after 2 minuets of run time. any solutions?
-Shmowland
Tue Feb 06 2024
853VES
Does anyone know why it may trip the fuse after 3 seconds when power is connected
[list]    [*] Variable Speed    [*] Digital time display w/ scrollable time setting    [*] Electronic braking    [*] Compact design uses less than 1 sq. ft. of counter space    [*] Full horizontal separation for test tubes up to 10mL    [*] Digital Cycle counter to monitor machine usage    [*] Horizontal Rotor comes standard    [*] Push-button operation/Safety lid-lock    [*] ETL Compliant to ANSI/UL Standards    [/list]
Height8.5 in
Length 12.5 in
Weight18.5 lbs
Width11 in
[list]    Max. Power Requirements: 165 Watts          Voltage: 115 (+/- 10)           Volts Frequency: 60 Hz    [/list]
