Drucker Diagnostics - 653ES
by Drucker Diagnostics
The Model 653ES has a digital time display which can be quickly changed from one (1) to ninety-nine (99) minutes. A mechanical cycle counter keeps track of the number of operation cycles. It is the most cost effective twelve (12) place centrifuge available today. Includes a "0" RPM safety lid lock. A wide variety of optional accessories are available to customize your centrifuge.
[list] [*] Digital Time Display w/ Scrollable Time Setting [*] Electronic Braking (may be disengaged) [*] Horizontal Rotor comes standard with centrifuge [*] Push-button Operation/Safety Lid-lock [*] Out-of-balance Detection [*] ETL Compliant to ANSI/UL Standards [*] Quiet Operation [/list]
Height | 9.5 in |
Length | 15 in |
Orientation | Benchtop |
Weight | 28 lbs |
Maximum Speed | 3150 rpm (± 100) |
Width | 12.5 in |
Capacity: Twelve (12) test tubes up to 17mm x 100mm
