Voluson Womens Health ultrasound has developed a strong reputation for high performance.
An excellent entry-point to the Voluson family, a Voluson P8 system delivers hard-working capabilities that fit user's practice, patient base, and budget...with an upgrade pathway that can help keep the system current for years to come.
FORUMSView All (12)
-Ayyoub
Sat Apr 08 2023
3D-4D ERROR
Hello i hope you're doing well i have an error on 3D-4D probes which is motor control unit no probe reference position signal detected and this problem for all 3D-4D probes would you help me to solve this problem and i need volusion P8 service manual best regards
Equipment: GE VOLUSION P8
-Guella
Sun Mar 05 2023
Probleme with probe of GE
Hi everybody, Can you please advice whats wrong, or what to do? My ultrasound machine GE p8.The unit says following: Motor control unit: No probe reference position signal detected. Thank you for your advice! Razan
Equipment: GE p8
-AGM
Fri Aug 27 2021
Patient ID
Is there a way to correct a patient ID if entered incorrectly Reply
  • Lightweight and portable
  • High Resolution Flat Panel Display 15”
  • Real-Time 4D
  • 3D Multiplanar Display
  • Automatic Optimization (AO)
  • CrossXBeamCRI* (CRI)
  • SonoNT
  • SonoRender Start
  • Anatomical M-Mode
  • On Board Archive including Preview and Pre-selection
Cart Based1
Height57 in
Length 26.4 in
Weight143 lbs
Clinical ApplicationsGeneral
Imaging Capabilities2D/3D
Portable1
Color-flow Mapping1
Doppler ModesSpectral Doppler Mode (PW, CW)
Image Display15 in
Imaging ModeB/M
Width16.5 in
[u]Electrical power [/u]           Voltage: 100-120 VAC, 220-240 VAC            Frequency: 50/60 Hz                         [u]Console design  [/u]          3 Active Probe Ports            Integrated HD (500 GB)
