GE HealthCare - Vivid E9
by GE HealthCare
Whether in 4D TTE or 4D TEE, capture the entire heart in a single beat. Image a valve, or the entire ventricle. And help break down the barriers to routine day-to-day 4D imaging, from acquisition, through navigation and quantification, to archiving. The Vivid E9 is available in both 2D and 4D configurations.
1ReplyThu Dec 26 2024 | Vivid E9 How can I use the version 110 permanent code on the Vivid E9 device after upgrading to version 112 Reply |
1ReplyThu Jan 11 2024 | Ultrasound Archive is currently turned off Equipment: GE vivid E9 Reply |
1ReplyTue Mar 22 2022 | Lower operational panel malfunction Hello, we have an issue with Vivid E9. Lower OP doesn't show any graphics (blackscreen) and deck knobs doesn't change any parameters after start. But LCD backlight lamp works and touchscreen reacts on tapping it in up left corner with sound in loudspeakers. Some of deck buttons are backlighted and start/stop button definitely works. Trackball works normally as well. All other Vivid E9 functionality seems to be ok. All cables' connections have been inspected and looked ok. What can be the reason of this issue and how to fix it? Thanks in advance for your ideas Reply |
| Cart Based | 1 |
| Clinical Applications | Cardiology |
| Imaging Capabilities | 4D |
| Portable | 1 |
| Color-flow Mapping | 1 |
| Image Display | 17 in The 17-inch all-digital high-definition LCD display tilts and swivels to a comfortable viewing angle. |
