Sorvall - RC-5B
Simplicity of operation and durability for intensive use.User-friendly controls make set-up simple even for inexperienced users, speeding up parameter setting and reducing errors. The industry’s widest rotor range – spanning fixed angle, swinging bucket, vertical, microtube, zonal, and continuous flow types – means unrivaled levels of superspeed versatility.
FORUMSView All (5)
1Reply4 years ago | System will not power on I have voltage and continuity to and thru the power switch/ breaker. Any idea where I can get a schismatic? Reply |
3Replies5 years ago | Temperature sensors not working I'm having problems with the temperature sensors, the black needle of the gauge hits hard the limit of the scale and stays there forever. The voltage divider of the galvanometer seems to be fine, all resistors are ok. I'm suspicious about the sensors. I can see that there are 2 of them. I have removed the lateral lid and am able to see clearly a K-type thermocouple wrapped inside a pipe and, strangly, its yellow connector is loose, it is not connected to anything. I don't see where it could be attached. As for the other sensor, it is the one inside the cylinder of the evaporator, it looks very strange to me, I cannot tell what kind of sensor it is, at first sight it resembles an optical fiber, it seems to have a core, but I'm expecting a thermistor or some kind of semiconductor like an LM35 or something like that. Coming out of the chamber there are two red wires connected to the sensor which outputs 2.7 V. So, my specific questions are: 1) Where should the thermocouple be connected?, 2) What kind of sensor is the one inside the chamber? 3) What should be the output of the sensor located inside the chamber? Thanks a lot, I would really appreciate your help.Reply |
1Reply5 years ago | How to replace brushes We have an RC5B+ we acquired used. It now needs the brushes replaced. It seems like a very difficult task, going from below and accessing the motor. If you've done it, how did you access the brushes? We are able to get there but it's not a routine task. Reply |
[list] [*] High-speed, refrigerated floor model [*] Universal/drive motor system [*] Reduced noise and maintenance [*] Fast and easy operation [*] Wide rotor range [/list]
Height | 45 in |
Length | 39 in |
Weight | 680 lbs |
Centrifuge Type | High Speed |
Width | 30 in |
[list] Maximum Speed: 21000 rpm Speed Range: 500 to 21000 rpm Speed Control Accuracy: +/- 1 percent or 100 rpm- whichever is greater Maximum RCF: 51070 x g Accel/Decel Rates: 1 acceleration, 2 deceleration Temperature Control Range: -20°C to +40°C Chamber: 16” diameter [/list]
