CareFusion - LTV 1200
by CareFusion
The LTV Series 1200 ventilator supports infant, pediatric and adult patients in ICU, ER and patient transport with invasive or noninvasive ventilation pre-sets. These settings can be easily refined using the touch-turn-touch interface on the LED display. The ventilator also provides a wide range of ventilation therapies to meet demanding patient needs, including volume control, pressure control, pressure support and spontaneous breath types. Combined with the spontaneous breathing trial function, the ultra-sensitive flow trigger facilitates weaning.
0RepliesFri Apr 03 2020 | Settings for CPAP on the LTV 1200 Ventilator Settings for CPAP on the LTV 1200 VentilatorReply |
0RepliesFri Apr 03 2020 | LTV 1200 ventilator: modes and settings LTV 1200 travel ventilator, modes and settingsReply |
0RepliesFri Apr 03 2020 | LTV Part 2: Initiating Ventilation and Changing Settings Overview of how to initiate ventilation and make basic changes with the LTV 1200 and how changing the inspiratory time changes the I:E ratio and flow.Reply |
[list] [*]Anytime transport - Turbine technology in the ventilator eliminates the need for a high-pressure air source, allowing transport ventilation where and when you need it [*]Optimizable trial settings - By optimizing trial settings for each of your patients, you can ensure favorable levels of support throughout the weaning process. [*]Oxygen resource management tool - The O2 Conserve feature reduces oxygen consumption as necessary, extending the sometimes scarce resource of oxygen during transport or emergency situations. It may be turned off when oxygen resources return to full supply. [/list]
| Height | 8.4 cm |
| Weight | 6.5 kg 14.5 lbs |
| Width | 27 cm |
