ConMed Linvatec - 35L
by ConMed Linvatec
Single Port Insufflator
The CONMED 35L Insufflator is an economical high-performance insufflation system. The 35L Insufflator utilizes many of the same features as the 40L Insufflator for safe distension pressure control during all phases of laparoscopic surgery. The 35L is also compatible with three CONMED insufflation tubing sets to ensure tubing standardization with existing insufflation systems.
-RenzoMed
Thu Jan 29 2015
Alarm co2
The machine produces co2 alarm and does not allow co2 output, even to connect a new co2 canister and not allow full co2 output
[list]      [*] 35 LPM maximum gas flow      [*] Gas Warmer compatible - ergonomic delivery of body temperature CO2      [*] Single gas output - simplicity and high performance      [*] Automatically adapts to E-tank and "wall" gas pressures      [*] Simple and intuitive operation      [/list]
Height6.9 in
Length 14.8 in
Weight23 lbs
Width13.3 in
Input Voltage Range: 90 - 240 VAC, 50 - 60 Hz
