Philips - M4841A
Central Station
The pocket-sized Philips IntelliVue M4841A telemetry transmitter is easy to connect and comfortable to wear. Its cable-less design cuts the clutter and enhances care and mobilization of patients throughout a facility. This compact, lightweight transmitter ensures accurate and dependable near-real-time transfer of vital signs to the information center.
FORUMSView All (13)
2Replies2 years ago | Philips - M4841A /Philips/M8105A (MP5) Monitor Can you run a Philips M4841A Transmitter and a Philips M8105A (MP5) Monitor on the same sector at the same time? If so, how do you connect both?Reply |
2Replies3 years ago | SPO2 Issue Philips M4841 Having an issue here where when SP02 is selected with our telemetry devices and an alarm triggers, when canceling/silencing the alarm, it also shuts off SP02 monitoring and we have to manually enable SPO2 monitoring each time. This happens with all PIICS (M3155) and with all wireless devices (M4841A). Any help is greatly appreciated. Thank you.Reply |
2Replies6 years ago | M4841A double beep Does anyone know which component on the main board causes the unit not to pass the post test? Ive changed the main board and it passes so that cancels out anything else. Any help would be greatly appreciated.Reply |
SERVICE COMPANIESView All Telemetry-Central Station Companies
VIDEOS
PAC FAQ: Philips Telemetry M26...
PacFaq- How To Assign A M4841A...
BMES Philips M4841A MAC Addres...
- Smart hopping technology locates the strongest available signal wherever the patient is located
- Bi-directional data with Cellular WMTS infrastructure for two-way communication between transceivers and the IntelliVue Information Center
- Wireless telemetry as a parameter (WTAAP) expands monitoring capabilities to provide untethered in-room access to ECG/SpO2 data in near-real time
- FAST-SpO2 (Fourier Artifact Suppression Technology) continually monitored or Spot Check with sensor LED indicator reliable measurement completed
- Integrated rechargeable Lithium-ion battery
- Battery gauge on transmitter
- Out-of-range audible alert
- Auto-resume of monitoring when a device comes back into network range
- Configurable volume levels
