Datascope - Expert
by Datascope
[list] [*] Dual-Vector ECG, Respiration, NIBP, SpO2, 2 Temperatures, and 2 Invasive Pressures in one compact SuperModule. [*] Multi-Lead ST Analysis and Arrhythmia Detection with waveform recall and analysis also standard. [*] Optional Cardiac Output module with hemodynamic calculations and output averaging cost-effectively expands capabilities. [*] Optional Dual Invasive Pressure modules add up to four additional invasive pressures. [*] High intensity, high resolution 10.4" removable color LCD display mounts easily to anesthetic gas machine. [*] Touchscreen and dedicated keys ensure fast, direct operations 6 user-programmable soft keys, 3-format display memory, and choice of 32 parameter colors provide maximum flexibility. [*] PCMCIA data card allows patient data and customized set-ups to be saved or transferred to another Expert Simultaneous display of up to 6 waveforms and 100-waveform event storage facilitate patient management. [*] Main unit, module housing, and display can be separately mounted when space is at a premium. [*] Optional Datascope Gas Module II provides breath-by-breath Fast O2, CO2, and N2O monitoring with automatic or manually-controlled 5-agent anesthetic measurement for real-time assessment [/list]
0RepliesTue Sep 30 2014 | Datascope Expert - Main Module Rom Err! Dear, Would like to know if some one of you have deal with this problem. We got a Rom Err! message from the module. Please give me some advice to solve this problem on the module. Best Regards... Reply |
