Philips - M3046A M3
by Philips
Multi-Parameter
The M3 (M3046) is a small, light patient monitor offering a flexible monitoring solution to suit a broad spectrum of monitoring needs. The monitor works together with the M3001A multi-measurement server (MMS) and the M3012A/M3015A/M3015A measurement server extensions to give you standard-of-care measurements.
-MedITtech
Tue May 12 2020
Connecting version M3046a D.11 and D.15 to Intellivue XDS L.00 - N.01
I am testing two Philips - Agilent M3046A patient monitors with M3000A servers attached with the Intellivue XDS suite and am running into a connectivity issue. Right now, XDS is installed on a Windows 10 PC (firewall off, 172.31.0.0/21 network segment), testing against version L.00 and N.01 to see if I can get the XDS software to connect with the monitors. Looking at the documentation, there should not be an issue but when I connect the monitors, I get "Monitor identity check failed: TIMEOUT [monitor name]". I can see the patient monitor in the Home Monitor list (trying one monitor at a time) and I can see the connection attempt to initiate but the connection drops. I have been looking for a compatibility matrix and additional settings I could change for the XDS platform (certificates, timeout settings, encryption levels, etc.) but I have not been able to locate any details. Any information you can share would be greatly appreciated!Reply
5
-William123
Mon Dec 08 2014
M3001A Pacer Not Captioning
When the MMS Module is connected to the monitor it flashed pacer not captioning on the screen. Is this a main board issue or an ECG board issue?
  • Patient demographics, measurement data and trends, acquired and stored in the MMS, can be transferred to the M-Series (M3/M4) and Philips Intellivue (MP60/70/90) patient monitors.
  • EASI derived 12 lead ECG using 5 electrode cable set.
  • Multi lead arrhythmia .
  • Up to 3 channels of ECG with basic arrhythmia and ST analysis capability.
  • FAST-SpO2 measurement, using Fourier Artifact Suppression Technology, for accurate performance even with low perfusion.
  • Respiration, non-invasive and invasive blood pressure and temperature measurements.
  • Mainstream or sidestream CO2 a second invasive blood pressure and temperature measurements and enhanced arrhythmia capability, available optionally.
  • Choice of serial interface for a dedicated external strip chart recorder (as default), or IrDA interface for connecting tot a local printer.
  • 3-wave or 4-wave displays are available.
  • Trend data, with manual and automatic event storage, together with a range of report styles help you track and document your patients progress.
  • Color display with a wide viewing angle.
  • Optional battery informs you of remaining capacity, and allows longer transport times. It can be easily exchanged during transport with no loss of settings.
  • Touch bar human interface - quick to learn and easy to use.
  • Rubber bezel protector, available in four colors, gives additional protection in transport scenarios.
