Canon - CXDI-40EC
by Canon
Flat-panel DR system
The Canon CXDI-40EC is a premium Digital Radiography system offering filmless x-ray capture for a broad range of radiographic applications, including trauma, general, pediatric and orthopedic exams.This Digital Radiography system consists of a Canon Amorphous Silicon (a-Si) Flat Panel Detector and a Cesium Iodide (CsI) scintillator, allowing for extremely effective x-ray absorption and high signal-to-noise performance.The CXDI-40EC is equipped with a large 17 inch x 17 inch imaging area for capturing images, large and small, without the need to adjust detector orientation.The versatile CXDI-40EC can upgrade your existing radiographic suite or can be retrofit to an upright stand, universal stand, or imaging table.
Immediate Results An on-screen preview image is available just 3-5 seconds after exposure.A monitor (not included) can be added for viewing high-resolution images in the emergency department or radiography suite. LANMIX MLT(S) Image Processing In addition to Canon’s advanced noise reduction processing, MLT(S) image processing utilizes the multiple frequencies within the image data to emphasize edges andCXDI-40ECdisplay appropriate dynamic range.Images of extremities, for example, show the subtle details of trabecular bone structure and soft tissue in high diagnostic accuracy.This process can be preset for repeatability as well as adjusted post-acquisition for variances in diagnostic requirements. Canon’s LANMIT® Technology Amorphous Silicon (a-Si) Flat Panel Sensor (LANMIT®) consists of a precision amorphous silicon metal-insulator semiconductor (MIS) sensor and Thin Film Transistor (TFT) array.LANMIT® flat panel sensors produce a highly stable output signal.The result is a family of reliable and durable sensors that provide the highest quality images without the time and costs involved with film or cassette handling.A 14-bit analog-to-digital conversion process converts the raw image to digital form producing a high-resolution, high-contrast 4,096 grayscale image. Seamless Network Integration Ethernet 10/100/1000 Base T connectivity with DICOM 3.0 compatibility enables seamless data transfer to any DICOM hard copy output device, PACS, or HIS/RIS for efficient printing, archiving, and remote viewing of images. The system complies with IHE (Integrating the Healthcare Enterprise) standards for interoperability to ensure easy, effective integration with the hospital network.
Height2.7 in
Length 21.7 in
Weight44 lbs
Detector TypeAmorphous Silicon
Pixel Matrix7.2 million pixels
Width21.7 in
Active detector dimensions 17 x 17 inches Pixel size, standard mode160 x 160 microns Bits per pixel of processed image 14 bits
