CareFusion - Vela Ventilator
Fully-functional and noninvasive positive pressure ventilatorThe VELA ventilator is a full-function and noninvasive positive pressure ventilator (NPPV) that provides high-performance tools to support patients throughout the continuum of care. Available as three models, the VELA ventilator offers a variety of features that can be customized to your specific ventilation needs. Also enabling analytics, the ventilator helps you support operational improvements and enhance patient care.
FORUMSView All (10)
4Replies2 years ago | Vent INOP Hello My Hospital has a ventilator Viasys Diamond Vela that gives me the error "Vent INop" and stops the ventilation. In the events show "Motor Fault" and XDCR Fault". Calibrate already the transducers and change the turbine, any suggestions? Reply |
1Reply3 years ago | IOP release When i turn on unit screen is black LCD is working but software does not working so anyone can help me? Thank you for supportReply |
3Replies4 years ago | Service Issue In Vela Carefusion--What is the reason of High VTe than VTi? and FiO2 monitoring calibration Failure ? O2 pressure is set at 50 PSIG and new O2 sensor changed. In normal ventilation we unit is monitoring 60-65% FiO2 while set FiO2 is 100%
Also needs user manual and sevice manual for this Ventilator. Reply |
VIDEOS
[list] [*] Invasive and noninvasive critical care ventilator [*] Pediatric through adult applications [*] Advanced settings to treat the most difficult-to-ventilate patient [*] Multiple noninvasive modes with automatic leak compensation to provide more ventilatory support options [*] Dual-limb noninvasive ventilation helps eliminate CO2 and rebreathing of exhaled gases [/list]
Height | 12 in |
Length | 14.5 in |
Weight | 38 lbs |
Width | 13 in |
