Conmed - Excalibur Plus PC
by Conmed
The ConMed Excalibur Plus PC is the most powerful isolated ESU available in its class. It allows the surgeon to adjust the power settings from the surgical field with a standard ES pencil. The Excalibur Plus PC patented Controlled Output Voltage in CUT maintains minimum necessary voltage for smooth cutting through various impedance tissues with minimal thermal damage.
1ReplySat Aug 07 2021 | Error in unit . Not working. Getting error , in cut its written ACC and in coag its written rH . Cautery is not working. I dont k kw how to calibrate .Reply |
1ReplyWed Jul 14 2021 | consumibles que tipo de electrodo de retorno a paciente utilizaReply |
3RepliesFri Jun 18 2021 | Error code 23.0 hi every one kindly help me I have an error in Conmed Excalibur Plus PC as 23.0 if anyone have a solution for this error?Reply |
[list] [*] 10,000V PTP in Spray COAG. [*] It is the only ESU that allows the surgeon to adjust power settings from the surgical field with a standard ES pencil. [*] Excalibur Plus PC Patented Controlled Output Voltage in CUT maintains minimum necessary voltage for smooth cutting through various impedance tissues with minimal thermal damage. [*] The Excalibur Plus PC offers a scalpel like cut and three blend modes. [/list]
Pure Cut Maximum Peak to Peak Voltage is 2000 Volts. Blend 1 - Maximum Peak to Peak Voltage is 2000 Volts. Blend 2 - Peak voltage of 2200. Blend 3 - The Excalibur Plus PC comes equiped with the maximum Peak to Peak Voltage of 2400.
