Datrend - MPS-2
by Datrend
The MPS-2 Multiparameter Simulator just may be the best value you can find in a dual-channel invasive blood pressure simulator on todays market.
The MPS-2 Multiparameter Simulator is a compact, cost-effective solution for biomedical engineers who need reliable, portable patient simulation capabilities. As the streamlined counterpart to the modular AMPS-1, the MPS-2 delivers many of the same powerful features in a fixed-function, non-modular format—ideal for routine clinical equipment testing and preventive maintenance.
This rugged, space-saving biomedical test device is designed to simulate a range of physiological parameters, making it a trusted tool in biomedical service, clinical engineering, and OEM device validation. (Generated by AI)
[list]    [*] Full 12-lead ECG with 9 independent outputs for each lead referenced          [*] ECG performance waveforms          [*] Respiration simulation          [*] Pacemaker waveforms          [*] Temperature simulation          [*] Arrhythmia simulation          [*] Automated protocols (user-programmable)          [*] Large easy-to-read display          [*] Extremely easy to operate          [*] Single 9-volt battery operation or use with an external AC power adapter for continuous simulation    [/list]
Height1.3 in
Length 5.5 in
Weight11.5 oz
Analyzer/Simulator TypePatient Simulator
Width3.6 in
