MAQUET - Alphastar
by MAQUET
The Alphastar surgical table, with electrically controlled hydraulic drive, provides essential table functions from table top positioning and auto-drive to reverse mode. AlphaStar can be modified to suit the needs of any surgical discipline in just a few quick steps ideal for smooth workflow in the operating room.
0RepliesThu Sep 18 2025 | Control Quisiera saber la posición de los cables que entran al control de una mesa quirúrgica Maquet alphastar Equipment: Maquet alphastar Translation: I would like to know the position of the cables that enter the control of a Maquet Alphastar surgical table.Reply |
1ReplyMon Jun 28 2021 | Alpha star 1132 the flex and level button does not work . does any one know what the problem could beReply |
1ReplyFri Dec 14 2018 | What kind of oil it use? I am looking for some information about the type of oil that it requires to operate, we aprecciate all the information you give us. Even we need the service manual to solve some troubles with the control. Thank youReply |
[list] [*] Electrically controlled hyfraulic drive for all the table's essential functions [*] Mounting point allows the quick use of a broad range of socket-mounted modules [*] Back-lit key panel considerably simplifies the work in the dark MIC room [/list]
| Height | 44 in Without Padding |
| Length | 82.5 in Length with head plate and extension plates |
| Weight | 660 lbs |
| Tredelenburg | 30 degrees |
| Lateral Tilt | 18 degrees |
| Patient Weight Capacity | 600 lbs |
| Width | 20.5 in |
