MAQUET - Betastar
by MAQUET
The BetaStar Surgical Table offers effective solutions for the widest variety of requirements in the OR. Patients benefit from superb positioning comfort with a maximum overall capacity of 454 kg (1,000 lbs)
FORUMSView All (3)
-Manly C M
2 years ago
How to service hydraulics of betastar 1131.12 OT table
How to open the main pillar section of the OT table to access the hydraulics as there's a leak
Equipment: maquet betastar 1131.12 OT table
-Zack Nelson
3 years ago
service manual
service manualReply
-Shan28
8 years ago
looking for Maquet Beta star service manual
Table is alarming when new remote control is powered and no functions will work. Only operates on override. Power supply and main board (along with chips on the board) were all replaced.
[list]      [*] Operating table top subdivided into six sections: head plate (optional), upper back plate (optional), lower back plate, seat plate, leg plates (optional)      [*] Seat and back supporting arms, leg plate sockets, joint covers and side rails made of chrome-nickel steel Multilayer SFC padding (Special Foam Core) for outstanding positioning comfort and highest patient safety, thickness of padding 80 mm / 3 inch      [*] Entire table top without crossbars for intraoperative fluoroscopy      [*] Patient orientation is set with the control units - Return to level button      [/list]
Height37 in without padding
Length 34 in without accessories
Weight573 lbs
Tredelenburg 30 degrees
Lateral Tilt20 degrees
Patient Weight Capacity1000 lbs
Width23 in with side rails
Electrical Specifications:    [list]    [*] Maintenance-free, special-design rechargeable batteries with capacity for about a week’s use in the OR     [*] The battery charge level is monitored electronically and indicated optically    [*] The operating table batteries are recharged with a mains cable    [*] Nominal voltages: 100/110-115/127/200/220/230-240 V AC (selectable)    [*] Class II, Type B; IEC 60601-1 • Nominal frequency 50/60 Hz    [/list]
