Datex Ohmeda - Excel 210 MRI
by Datex Ohmeda
Anesthesia Machine
[list]  [*] Specially designed for use in the MRI environment.              [*] The MRI-Compatible is a three-gas machine, which can accommodate two vaporizers.              [*] Primarily constructed of non-ferrous materials to help protect against attraction to the cryogenic magnets, which reside within MRI systems.  [/list]
Height52 in
GasesAir, Nitrous Oxide, Oxygen
Length 33 in
Vaporizers (Max)Two
Weight296 lbs
Width40.7 in
Volume of CO2 absorber: 1.5 Liter, Option: Dräger Medical’s prefilled CLIC absorber (1.2 l)          Gas Supply: O2, N2O & Air          Cylinder yokes: O2, N2O, Air, pin index yokes          Power Supply: 100 - 240 VAC, 50/60 Hz, 2.3 A max. (non-configurable)          Operation Time: Up to 120 minutes, minimum 45 minutes; with fully charged batteries Ventilator E-vent: Electronically controlled, electrically driven          Operating Modes Standard: Volume Controlled Ventilation, Manual Ventilation, Spontaneous Breathing           Operating Modes Options: Pressure Controlled Ventilation, Pressure Support          Breathing Frequency: 4 to 60 1/min          Max. Minute Volume: 0 to 99.9 L/min
