Gaymar - TP-200
by Gaymar
Provides localized warming therapy with precise temperature control.
The Gaymar TP-200 uses heat therapy by supplying temperature-controlled water through a connector hose to a Gaymar T/Pad. The pad’s design allows warm water to flow through the pad and out the other side, dilating the blood vessels and increasing blood flow to the heated areas. More than one pad can also be interconnected to provide therapy to more than one body site at a time. The temperature desired is set on the units front panel controls, and the circulating water maintains the pad at the set point temperature.
The T/Pump has two limit thermostats which will shut off the pump automatically is the high-temperature limit is exceeded; a warning light on the front panel, the "over temp" light, will illuminate if this occurs. The unit also incorporates a tip-over switch which shuts off the unit if it is overturned.
-sulsapj
Sat Jan 11 2014
TP200 w/Sluggish Motor
I have a Gaymar TP200 (very similar to the TP400 but there is no MedWrench page for it).  It has a Jakel motor.  The motor has an odd behavior in that it runs sluggishly (fan blade and thus impeller turn but not sufficiently so to pump water) for up to five minutes before suddenly attaining normal speed,  I have oiled the motor with Anderol 465 synthetic oil. The unit checks out in all other ways per the TP400 service manual.  Any ideas?
  • Low water alarm and shut off
  • Pump has two limit thermostats which will shut off the pump automatically if the high-temperature limit is exceeded
  • Temperature settings of 85-105 degrees F (30-41 degrees C)
Reservoir Capacity: 1500 m
Flow Rate: 9-14 gph
