Vitalograph - ALPHA 6000
Performing spirometry tests could not be easier than with the All-in-One screening spirometer.Vitalograph ALPHA is an easy to use, lightweight desktop spirometer that delivers an ideal combination of portability, speed and accuracy. ALPHA's low cost spirometry testing is enhanced by a precise and robust Fleisch pneumotachograph and a high resolution colour screen
FORUMSView All (7)
0Replies10 months ago | service paasword Goodday, what is the service password for vitalograph 6000 Equipment: Vitalograph - ALPHA 6000 Reply |
0Replies4 years ago | Service pass for Alpha 600 Hi, anyone knows how login to service mode? also what is this password? the devices shows service message .. and I wont to clear it after PPM servicing Regards SSReply |
2Replies4 years ago | cleaning how do you clean this machine ?Reply |
- Dedicated all-in-one desktop unit
- Simple to use
- Rapid and low cost testing
- Clear and bright colour screen
- Accurate fleisch pneumotachograph
- Measures VC, FVC, FEV1, IC, FEV1%, PEF,FEF 25-75 and more
- On-screen visualisation of volume/time and flow/volume curves
- Saves multiple pre-tests for subsequent post-testing
- Removable memory card slot
- Presents the test information in clear, easy to read format
- Links to PC, via USB, with report generation software
- Fast, silent printer that prints 140 tests per roll
Voltage: 110 - 250V~ 50/60Hz
Flow detection principle: fleisch type pneumotachograph
Volume detection: flow integration
Maximum displayed volume: 8 liters
Maximum test duration (FVC): 20 seconds
Flow impedance: <0.1 kPa/L/s @ 14 L/s
