Nanosonics - Trophon EPR
by Nanosonics
Washer/Decontaminator
The Trophon EPR is a complete ultrasound transducer High-Level Disinfection system thats fast, easy to use, environmentally friendly and quality assured. It uses a unique platform technology to effectively disinfect the transducer, including the shaft and handlein just seven minutes between patients.
FORUMSView All (41)
-ShawnL54
Invalid Date
Service manual
Looking to find a service manual for the Nanosonics Trophon EPR
Equipment: nanosonics trophon epr
-Zalazar
Invalid Date
Nanosonic Trophon EPR error code BF032
Hello ,
What is the ERROR BF 032?
-ShawnL54
Invalid Date
Can someone tell me where I can get the service manual for the Nanosonics Trophon EPR? Thanks.
VIDEOS
Trophon EPR
  • The Trophon EPR is simple and cost effective to use
  • The Trophon EPR stores all disinfection cycle data which can be downloaded on a request basis or at your 12 monthly preventative maintenance service
  • There are only two items required for use with the Trophon EPR to deliver high level disinfection
Height19.3 in
Length 13.6 in
Weight38 lbs
Width13.6 in
  • Cycle Time: 7 minutes
  • Cycle Verification: Via User Screen, Chemical Indicator and Electronic Log.
  • Sonex-HL: Minimum Concentration 31.5% Minimum Disinfectant Dose 1.0 g Volume  80 ml, 40 cycles/cartridge Shelf Life  2 years
  • Chemical Indicators: The Chemical Indicators are used exclusively for monitoring the High-Level Disinfection process when placed within the Trophon EPR chamber. The color of the indicator changes from red to yellow when exposed to hydrogen peroxide.
  • Probe Compatibility: Please check with your transducer manufacturer regarding compatibility with the Trophon EPR. You can also find a validated transducer list at www.trophon.com
  • Electrical Requirements: Input Voltage: 120V AC   Input Current: 5 Amp/50-60 Hz
  • Agency Approvals: UL61010-1:2004 R10.08, IEC61010-2-040:2005, CAN/CSA-C22.2 NO. 61010-1-04+GI1 (R2009), CAN/CSA-C22.2 NO. 61010-2-040-07
  • EMC Compliance: EN61326-1:2006 FCC Rules Part 15 Subpart B Unintentional Radiators, Class B Digital Devices ANSI C63.4:2009
