Medelec/TECA - TD-10
by Medelec/TECA
Single channel EMG with integraged chart recorder, preamplifier and nerve conduction stimulator.
FORUMSView All (5)
-Luis@
Thu Jun 25 2020
OWNERS MANUAL
dO YOU HAVE IT? OR WHERE CAN I GET IT?Reply
2
-The Agnew Clinic
Mon Oct 15 2018
Need to repair NCV/ f-wave feature
Can you provide a contact in Santa Barbara area?Reply
-1937FORD
Wed Jul 16 2014
What does error code: Fail 2 mean in a TECA TD-10 MK-1 EEG?
Does any one know what this error code means? Dr. has NOTHING  on this device and I can't find anything about it anywhere. HELP!! THX!!!
SERVICE COMPANIESView All Electromyograph (EMG) Companies
[*] Complete clinical EMG system with recorder  [*] A microprocessor based system designed to provide a simple method of acquiring and analyzing neurophysiological signal  [*] Signals are acquired from the patient using suitable electrodes and are then amplified and filtered for display on the cathode ray tube.
Height175 mm
Frequency Range50 to 60 Hz
Length 380 mm
Weight15 kg
Power Source100/110/120/200/220 and 240 V +/-10%
ChannelsSingle Channel Chart Recorder
NoiseNoise referred to input: <6μV pk to pk (2 Hz to 10 kHz with input short circuited).
Width455 mm
Display: 120 x 85 mm cathode tube. Real time and Flicker free dual trace display; 2x100 pts. The two traces may be superimposed at any time in any mode to facilitate direct comparison.    Time/Div: 0.2, 0.5, 1, 2, 5, 10, 20, 50 and 100ms/div.    Analysis duration: 10div.    Signal Acquisition: Continuous and triggered from signal, stimulus or external source.    For external acquire control, a contact closure or negative TTL pulse of 100ms minimum duration is required.    Time Measurement:    Two cursors are provided for measuring latency, duration, delay or amplitude difference.    The cursor positions are indicated by bright spots on both traces. Digital identification is provided of time from start of trace to each cursor and amplitude difference between cursors.
