Beckman Coulter - Access 2
by Beckman Coulter
Immunoassay System
The Access 2 delivers an extensive immunoassay diagnostic-testing menu that includes sTfR in our anemia panel as well as SHBG and Testosterone in our comprehensive reproductive panel. The Access 2 was designed to have the robustness of a reference-lab immunoassay analyzer in the convenient size of a bench-top instrument.
FORUMSView All (8)
-Makenna Jones
Wed Apr 16 2025
Reagent Pack Deleted
When I unloaded a reagent pack, it won't let me re-load it because the analyzer says that it has been deleted. There is no way to override the deletion of a reagent pack, and I did not manually delete it
-Makenna Jones
Wed Apr 16 2025
Calibration Reagent Error
When I order a calibration, the supply screen prompts me to load a reagent pack for that assay before it can begin calibration, but there is already a reagent pack loaded, and it is recognized in the reagent inventory.
-AJSCL
Wed Nov 06 2024
Beckman Coulter Access 2 Issues
Having problem with the cooling system. Reagent carousal is not cooling to the required temperature. Also, getting errors, "Reagent Carousal sensor not found. and sample carousal sensor not found."
  • One of the smallest bench-top analyzers in its class
  • Runs up to 100 tests per hour
  • STAT and automatic reflex testing
  • Sample probe obstruction detection
  • Magnetic particle separation
  • Chemiluminescent detection technology
  • Over 50 available immunoassay diagnostic assays
  • Continuous menu expansion with new and novel assays
  • Simple, user-friendly interface
  • Easy-to-Use, Easy-to-Store Reagent Kits.
  • Up to 56 day reagent open-pack stability
  • Load up to 60 samples at one time
Height18.5 in
Length 39 in
Weight200 lbs
Width24 in
  • Analytic unit - 15A at 115-120 VAC or 6A at 220-240 VAC (50/60 Hz)
  • Heat Output- 2,730 BTU/hr (analytic unit)
  • Ambient Operating Environment - Ambient Temperature +18°C to +28°C Relative Humidity: 20 to 80% relative, non-condensing
  • Altitude- 6,500 ft. (2,000 m)
  • Ambient Light- 0 to 200 foot candles
