Siemens - Sonoline Prima
by Siemens
The Sonoline Prima features an Enhanced Obstetrical Analysis Package with user-defined table, formulas, and growth graph trending and a prostate brachytherapy option for a software-installable on-screen template.
0RepliesSun Apr 05 2026 | Software simmen sonoline Hello friend, I apologize, I saw your message on the .medwrench.com page. I hope you can help me. I'm looking for the software for the Simmen Sonoline Prima scanner. I understand it's on 3.5-inch floppy disks, but the scanner is asking for a 1-inch disk. I hope you can help me, and thank you very much. Equipment: simmen sonoline prima Reply |
0RepliesTue Nov 21 2023 | failing negative DC Power Anybody familiar with the problem that US probe does not work because negative DC voltage supply fails as well as +100V DC according to diagnostics using F4 key and accessing respective menu Reply |
25RepliesThu Jun 09 2022 | No system. Insert system disk Please how can I get disk for sonoline prima. Send me a mail please. alphonsuspaul83@gmail.comReply |
| Cart Based | 1 |
| Height | 50.8 in |
| Length | 23.6 in |
| Weight | 190 lbs |
| Clinical Applications | Urology |
| Portable | 1 |
| Image Display | 12 in |
| Imaging Mode | B/M |
| Width | 19 in |
FRAME PACE, FPS (SOFTWARE CHARACTERISTICS): Up to 74 POWER NEEDED: 115/200/230 VAC, 50/60 Hz, 20 A Image storage: 1.44MB floppy disk (3.5") Stored image capacity (FUNCTIONS): Up to 14
