Draeger - Oxylog 3000
The Drager Oxylog 3000 Ventilator offers sophisticated ventilation for patients in emergency situations and during transport in and between hospitals.The Drager Oxylog 3000 Ventilator offers sophisticated ventilation for patients in emergency situations and during transport in and between hospitals. Designed to support a wide range of patients and medical conditions, Drager Oxylog 3000 Ventilator offers volume and pressure based modes, for controlled, synchronized or spontaneous ventilation. When transporting critical care patients, the need of interrupting ventilation therapy is therefore eliminated. Non invasive ventilation (NIV) reduces the need for intubation. Clear flow and pressure curves are shown on a high-contrast display, offering reliable patient monitoring. Drager Oxylog 3000 Ventilator is designed to be used both in the hospital and outdoors. Its robustness and transportability in combination with the wide range of ventilation modes and monitoring options support patient care and improved outcomes. No need to compromise in therapy performance, patient safety and transportability.
FORUMSView All (5)
1Reply2 years ago | Password - Service Manual i need the password or the service manual of the portable ventilator Drager VE300, please.Reply |
2Replies4 years ago | Charging Board Hi, I have 2 Drager Oxylog 3000. When I put the batteries in unit works plugged in charger doesnt work. Im assuming the charging board damaged Any one help in this regard? Kind regards Reply |
2Replies5 years ago | Service manual anyone has the service manual for Drager- Oxylog 3000? Reply |
VIDEOS
[list] [*] High confidence during transport [*] Integrated capnography [*] Automatic altitude compensation (BTPS) [*] Advanced data export functionality [*] Wide range of ventilation modes and AutoFlow [*] Ready for paediatric patients [*] Dräger user interface and family platform [/list]
Height | 184 mm |
Length | 175 mm |
Weight | 8.5 kg |
Width | 290 mm |
FDA AlertsView All
Class 1 Recall: Dräger Recalls VentStar Oxylog 3000 Pediatric...
The firm discovered that the check valve on the circuit may leak. This could result in the patient re-breathing exhaled gas with reduced oxygen concentration and increased carbon dioxide levels.
Class 1 Recall: Dräger Medical Inc. Recalls Emergency Transport...
Dräger is recalling the Oxylog Emergency Transport Ventilators because an electrical issue may cause the device to stop working if the control knobs (adjustment potentiometers) are not regularly used.
