Radcal - Dynalyzer
by Radcal
The Dynalyzer IIIU is one of the most accurate tools for the calibration and analysis of x-ray generator systems.
The Dynalyzer III connects between the generator and x-ray tube to isolate signals and deliver precise, direct kV, mA, and filament current measurements. Its ground-referenced analog outputs interface seamlessly with external test equipment like the Dynalyzer III Digital Display or an oscilloscope. Unlike non-invasive testers, the Dynalyzer provides true kV readings unaffected by tube target material or filtration.
Dynalyzer III Digital Display / Printer
Part of the complete Dynalyzer system, this digital display unit offers fast, accurate x-ray calibration, compliance testing, and troubleshooting. Compatible with Dynalyzer II, III, IIIA-CT, and IIIU High Voltage Units, it supports integration with oscilloscopes and voltmeters for comprehensive x-ray system analysis. (Generated by AI)
[list]          [*] Measure kVp           [*] Measure Fluoro           [*] kV Delay           [*] Exposure Recall           [*] Coefficient of Variation          [/list]
Analyzer/Simulator TypeX-ray Measurement System
kV Accuracy ± 1% 10 kV to 150 kV        Anode Current ± 2% 1 mA to 2 Amps (8ms pulse maximum) Selectable sensitivity for more accuracy at low mA        Filament Current ± 1% db (12%) DC to 20 kHz
