Terumo - TE-331
In order to minimize the risk of ADES, the TE-311 syringe pump is equipped with several safety features.In order to minimize the risk of ADES, the TE-311 syringe pump is equipped with several safety features. The risk of reading mistakes or misprogramming of the flow rate will be reduced thanks to the large, orange coloured decimal point and the difference in size between the digits and the decimal places. The pump is also equipped with a unique user friendly and ergonomically designed dial to help eliminate mistakes whilst programming the settings. When the flow rate is set higher than 10 mL/h the pump will give a warning sound.
The syringe can no longer be wrongly placed thanks to the barrel detection function and the larger plunger clamps.
The pump meet the safety requirements of EN 60601-1, EN 60601-2, EN 60601-1-4 and EN 60601-2-24.
All our syringe pumps can be used with 10, 20, 30 and 50 ml syringes from Terumo and other specified brands. The correctness of our flow rate is within 1% for mechanical accuracy and within 3% for accuracy including the syringe.
FORUMSView All (10)
0Replies3 years ago | Still parts available May I ask if syringe pump - Terumo TE 331 are still available? I need a need front housing to replace the broken one. Reply |
1Reply4 years ago | service manual selector switch problemReply |
0Replies6 years ago | No Protective earth why the syringe pump in class 1 classification but do not have protective earth?Reply |
- Display for safe parameter settings
- Unique dial setting
- Fast and unmistakable syringe placement
- Solid design
- Clear alarm monitor
Height | 114 mm |
Length | 115 mm |
Flow Rate Range | 0.1 to 999 ml/h |
Weight | 1.8 kg |
Flow Accuracy | 3 % |
Infusion Pump Type | General-Purpose |
Width | 322 mm |
