Carolina Liquid Chemistries Corp. - BioLis24i
by Carolina Liquid Chemistries Corp.
Fully automated, discrete, access chemistry analyzer with random water system.
This eco-friendly benchtop chemistry analyzer has a menu of 100 tests, including general chemistry, special chemistry, and drugs of abuse tests. It can run over 400 tests per hour and can analyze 3–30uL of serum, plasma, or urine using endpoint, rate, ISE, and turbidimetry analytical methods. Bi-directional interface and barcoded primary tube sampling provide positive sample ID and eliminate the need for instrument programming.
The system uses semi-permanent reaction cuvettes and an integrated distilled water system to eliminate the need for expensive disposable cuvettes and water cubes. A thorough, 10-step cuvette wash station administers heated alkaline and acid washes before and after each run. The analyzer is compatible with all LIS systems, eliminating the need for paper documents. Reagents are barcoded, ready-to-use liquids. 30-day on-board reagent stability and 14-day calibration stability allow for easy daily start-up.
-bblab
8 years ago
biolabo hba1c reagent by biolis 24i
Does any have Biolabo HBA1C reagent adaptation  for biolis 24i.
Thanks
  • 400 tests per hour
  • Requires no disposable cuvettes
  • 100 chemistry tests available
  • Barcoded sample tubes
  • Barcoded reagents
  • Bi-directional interface
  • 30-day on-board stability
  • 14-day calibration stability
  • 24 hour reagent cooling
Height20.5 in
Sample CapacitySample cup, primary tube (5, 7, 10 ml)
Throughput400 samples/hr
Length 26.5 in
DetectorAntigen excess detection
Power Requirements110/220 VAC
Weight210 lbs
Optical SystemBi-chromatic
Light SourceTungsten halogen lamp
Sample TypesSerum, plasma, urine, CSF
Sample Volume3 to 30 µL
Reaction MethodColormetric-rate
Width31.5 in
