Carolina Liquid Chemistries Corp. - CLC480
by Carolina Liquid Chemistries Corp.
Routine chemistry. Special chemistry. Drugs of abuse.
The best bench-top clinical chemistry analyzer on the market, this analyzer is also useful as an affordable backup, STAT lab analyzer or special chemistry analyzer. Features of a high throughput floor model built into a compact affordable bench top. Discover how your can reap the benefits of a speedy, efficient and economical chemistry analyzer . Experience the capabilities of the CLC480 bench top chemistry analyzer.        With more than 4,000 CLC480 chemistry analyzers in use worldwide, this chemistry analyzer is a trusted bench top solution for clinical laboratories located in physician offices. This analyzer is also useful as an affordable back up analyzer or stat lab analyzer.
FORUMSView All (3)
-DPetersen
5 years ago
Doctor drop down menu
How do you delete a doctor from the drop down menu?Reply
-Wilda
8 years ago
Where can i get a free downloaded users manual
Where can i get a free downloaded users manualReply
-Paindoc
10 years ago
CLC 480
Does this device provide quantitative assays for urine drug testing?
[list]    [*] Discrete, random access, fully automated    [*] Up to 240 photometric plus 160 ISE, up to 400 tests/hour    [*] No disposable cuvettes required    [*] Barcoded sample tubes and ready-to-use reagents    [*] Bidirectional interface with host query    [*] Electrolytes by ion selection electrodes    [*] 30-day onboard reagent stability    [*] 14-day calibration stability (for most analytes)    [*] 24 hour reagent cooling    [*] STAT capabilities    [*] Less operational noise    [*] Access to up to 100 CLC reagents with peer group survey    [/list]
Height20.5 in
Sample CapacitySample cup, primary tube (5, 7, 10 ml)
Throughput400 samples/hr
Wavelength Range340 to 800 nm
Length 26.5 in
Power Requirements110/220 VAC
Weight210 lbs
Optical SystemTungsten halogen lamp
Reaction Time24 hr
Light SourceBi-chromatic
Sample TypesSerum, plasma, urine, CSF
Sample Volume3 to 30 µL
Width31.5 in
