Carolina Liquid Chemistries Corp. - CLC720
by Carolina Liquid Chemistries Corp.
Analyzes 100 different blood chemistry tests, such as glucose, cholesterol and drugs of abuse with a throughput of 400 photometric tests/hour.
The systems design is greener, which means it generates less heat, operates more quietly and consumes 40 percent less chemicals, 25 percent less water, 20 percent less serum and 50 percent less electricity. The CLC 720 also takes up 25 percent less space and is less expensive than other systems in its class.
-Statlab
6 years ago
software
My CLC 720 only has drug of abuse screening software. Anyone know were I can get a copy of the chemistry software?Reply
  • Discrete, random access, fully automated
  • Up to 560 tests per hour with ISE
  • Up to 77 onboard chemistries plus Na+, K+, Cl-
  • Refrigerated reagent compartment
  • Sample tray: 90 positions
  • Automatic probe cleaning, liquid level detection, clot detection, probe collision protection 8-step auto washing system
  • 12 wavelengths: 340~800nm
  • Automatic dilution of high samples above usable range
  • Internal reagent and sample barcode reader
  • Bi-directional LIS interface with host query
  • Eliminates the need for cumbersome racks
  • Pre-dilution for certain assays
  • STAT capabilities
Height45 in
Throughput400 samples/hr
Length 27 in
Power Requirements100-120 VAC
Weight551 lbs
Optical SystemReversed optics, grating photometry
Light Sourcehalogen-tungsten lamp
Sample TypesPre-dilution and post-dilution with ratio up to 1:150
Sample Volume2 to 45 µL
Width46
