Nestle HealthCare Nutrition, Inc. - Compat Dualflo
Compat Dualflo Enteral Feeding Pump is an easy to use, versatile device for the administration of all enteral feeding solutions.Compat Dualflo Enteral Feeding Pump is an easy to use, versatile device for the administration of all enteral feeding solutions. It is an advanced delivery system designed to administer tube feeding formula and water for patient hydration. Users can program the pump to provide individualized patient hydration protocols, automatic flushes of the feeding tube or formula at pre-set strength.
[list] [*] Delivery-set security doors reduce the chance of set dislodgement and alarms and stops the pump if opened during normal operation [*] Memory features lifetime retention of infusion rate, dose limit, formula strength, water volume set, time interval, formula and water delivered and accumulated volume [*] Audio and visual alarms include occlusion or empty container, dose complete, low battery and open delivery set door [*] Water volume set interval: 0ml to 500ml in 1ml increments, 2 to 12 hours in 1 hour increments [*] Large LED display window, alternates displaying delivery rate and volume delivered when pump is running [*] Battery lasts upto 8 hours at 100ml per hour and is rechargeable while pump is operating [*] Self-diagnostic mode allows for complete circuitry check when pump is turned on [*] Dose limit for Intermittent Feeding with choice of 3 dose complete alarm modesettings without interruption of feeding [*] Lightweight and portable, the pump is 7lb and can clamp to any IV pole [/list]
Height | 6.4 in |
Length | 5 in |
Weight | 7 lbs |
Width | 9.75 in |
