Compat Enteral Feeding Pump is versatile, lightweight and easy to use feeding pump designed for the administration of enteral tube feeding formulas.Compat Enteral Feeding Pump is versatile, lightweight and easy to use feeding pump designed for the administration of enteral tube feeding formulas. The new molded bracket securely holds the administration set in place. The dual display window allows the caregiver to monitor infusion rate, volume delivered, and dose limit simultaneously. It is accurate and easy to set up and adjust.
- Compat Enteral Feeding Pump has flat surfaces which allows for easy cleaning
- Flow rate accuracy: +/- 10% of selected flow rate
- Dose limit: Dose adjustable (5ml increments) from 0 to 9995ml
- Automatically stops after predetermined volume is delivered
- 3 alarm options to signal dose complete
- Memory features lifetime retention of infusion rate, dose limit, volume delivered and accumulated volume, even after unit is turned off
- Audio and visual alarms include occlusion or empty container, battery on, low battery, rate change, dose complete and free flow
