Beckman Coulter - DU 530
by Beckman Coulter
Colorimeter
The DU-530 is a simple but great spectrometer that comes with various built-in programs that are easy to use. This system uses a single cell module that that uses a wide variety of cell holders such as, the 1cm standard, 16mm test tube, 5cm and 10cm rectangular and a 50µl microcell. The Beckman DU 530 is a great basic research grade instrument that you’ll never need the operating manual to operate. It uses a Single Cell Module which supports a variety of optional cell holders including the 16mm test tube 1cm standard 5cm and 10cm rectangular turbidity and 50uL microcell . Typical starting configuration is the single cell cuvette holder.
FORUMSView All (5)
-Cann-Med
Thu Dec 02 2021
Self Test Issue
I have a Beckman DU530 that doesn't pass the calibration test on start up. Any idea what that might be?Reply
-ChrisPK
Wed Mar 24 2021
Beckman Coulter - DU 530 service manual
I need a service manual to troubleshoot the power supply. Or a wiring diagram. Regards, ChrisReply
2
-ANIS KH
Wed Apr 22 2020
service manual BECKMAN DU520
I need the service manual of beckman du 520 thank's anisReply
  • Completely modular UV-Vis Spectrophotometer
  • Easy sample handling and operation (no manual required)
  • Fixed wavelength or scanning mode
  • Complete and Integrated System for Routine Applications
  • Generic Standard Features Single Cell Module which supports a variety of cell holders
  • Graphical Liquid Crystal Display Keyboard
  • Alphanumeric Soft-pad 100 User Programs Methods and Data Storage
  • Fixed Wavelength Mode
  • Scanning Mode
  • Time-Based Kinetics
  • Single Component Analysis
  • Protein Analysis
  • Nucleic Acid Analysis with DNA/RNA/Oligo Quantitation & purity checks
  • Cell module: 1 cm
  • Wavelength range:190-1100 nm
  • Spectral Slit Width: < 4.2 nm
  • Photometric Repeatability: ± 0.1 nm
  • Programs for Methods: 100 user data store
  • Interface:Serial RS-232/Parallel port
  • Software: Multi-language
