HESKA - Element DC
by HESKA
Take the elements of in-house lab chemistry further with the NEW Element DC analyzer.
Enhanced patient staging, faster result times and a touchscreen interface make this instrument an essential component to fast answers and accurate treatment decisions.
-RandalMed
6 years ago
Parts or replacement parts for the Heska Element DC
I need to locate the power on button of the Heska Element DC model NX500IV. They can help me find out where I can buy it.Reply
-MedWrenchManager
11 years ago
Heska Element DC Chemistry Analyzer
Take the elements of in-house lab chemistry further with the NEW Element DC analyzer. Enhanced patient staging, faster result times and a touchscreen interface make this instrument an essential component to fast answers and accurate treatment decisions.
VIDEOS
[list]    [*] Now with E-Wrap! Turn the convenience of our pre-surgical and comprehensive panels into a 1-step timesaver.    [*] Electrolytes and More: Electrolytes on one slide, pre-packaged panels (including the Comprehensive Plus), and individual slide options let you configure the profiles you require.    [*] Whole Blood Solution: Heska’s lithium heparin sample tubes save you a step. Go from syringe to centrifuge to analyzer with no pipetting required.    Sampling Flexibility: Choose the 1.5-ml heparinized sample tube, or pipette serum or plasma from your regular green-top or red-top tubes into a non-heparinized tube.    [*] Whole Blood Solution: Heska’s lithium heparin sample tubes save you a step. Go from syringe to centrifuge to analyzer with no pipetting required.    [*] Additional testing at the touch of a button: Add a new slide to your patient’s panel even after the analysis has begun.          [*] Stack and Run: Load up to 22 tests (20 slides) at one time without jamming, using the convenient stackable slide rack.    [/list]
Height16.5 in
Sample Capacity20 slides
Throughput128 samples/hr
Length 14.2 in
Power Requirements100-240 VAC
Weight53 lbs
Light SourceHalogen lamp (6V, 10W)
Width18.5 in
[list]    Incubation Temperature: 98.6° F (37° C) (CM); 86° F (30° C) (ISE)  Measurement Precision: 0.0004 OD/5 minutes        Display: 5.7 in. color touch panel          Measurement Wavelengths: 400 nm, 415 nm, 505 nm, 540 nm, 577 nm, 600 nm, 625 nm, 650 nm  [/list]
