Spacelabs - 90367 Ultraview
by Spacelabs
Fully PCIS™/Ultraview Care Network-compatible and are designed for use as small bedside monitors or as battery-operated transport monitors.
The 90367 Ultraview® 1030 monitor and the 90369 Ultraview 1050 monitor are fully PCIS™/Ultraview Care Network-compatible and are designed for use as small bedside monitors or as battery-operated transport monitors. These monitors feature a 10.4-inch color display and an infrared touchscreen, and they can be operated on either mains power or battery. A single-high module slot on the right side of the monitor accepts all single-high modules, including the 90470 Multiparameter module, 90496 Ultraview Command module, and 91496 Ultraview SL™ Command module, to permit monitoring of parameters such as ECG, temperature, and invasive pressure. The optional 90310 Wireless Network Interface (WNI) provides a seamless network of communications with other Ultraview PCIS/PCMS™ monitors via a Wireless Local Area Network (WLAN). These flexible networks use the 90310 as the point of airwave transmit and receive for the Ethernet network interface. Networks can use a single channel or multiple channels with additional 90310 WNIs (the number required depends upon the number of waveforms per monitor and the number of monitors in use). The capnography option provides integrated monitoring of EtCO2, inspired CO2, and respiratory rate. This option allows an external oxygen sensor to be attached to the Ultraview 1030/1050 transport monitor, which measures the FiO2 parameter and adjusts the CO2 reading to compensate for the presence of O2.
FORUMSView All (3)
-noe
Thu Aug 03 2017
Manual de uso y operación
Buenas tardes deseo saber si los amigos tuvieran este manual con la finalidad de compartirlo con mi persona para fines de configuración de algunos parametros de este monitor ya que no he podido realizarlo adecuadamente le estaré muy agradecido mi correo carlosnoe2425@gmail.comReply
4
-isadcari
Thu Nov 10 2016
POwer supply connector
Hey is there any schematics on the power supply a diode broke and cant read the number to replace it, its  a condor GPM55-24.
Or if you know any power supply that can be replace with
-Jere
Fri May 30 2014
Ultraview SL 91367
Is anyone having Inverter bd problems with this model. We have had this model for about 5 yrs now. We just had 3 monitors in the past 2 months need a new inverter bd.
