Spacelabs - 91369 Ultraview SL
by Spacelabs
Portable monitor designed for use as a compact bedside monitor or as a battery-operated transport monitor.
Spacelabs 91369 Ultraview SL Compact Monitor has a large 10.4 inch touchscreen display. Like the 90369, this unit uses dual-battery slots which make this Ultraview very portable. All prior and current Spacelabs modules are compatible with the 91369. The 91369 monitor is a lightweight, portable monitor designed for use as a compact bedside monitor or as a battery-operated transport monitor. The monitor features a five-wire, resistive touchscreen and can be operated on either AC mains or battery power. The single-high module slot on the right side of the monitor accepts all single-high modules, including the 90496 Ultraview® Command module and 91496 Ultraview SL™ Command module, to permit the monitoring of parameters such as electrocardiography (ECG), pulse oximetry (SpO2), temperature, and invasive pressure.
7Replies5 years ago | serial out of data hi, i want to take the instantaneous values of SPO2 from the device to draw the SPO2 waves exactly shown in the monitor.. How to enable this facility in the device? Is there any option to enable it? How it is drawn in the device? Which calculation is using to draw it? Please help me to solve itReply |
4Replies5 years ago | display blinking hi!!! i come across with the issue that monitor start blinking every 20 seconds .During blinks there will be a line on spo2 graph.we check the data log in service function shows temperature out of spec....i check the fan condition is ok.Reply |
1Reply7 years ago | classes full Reply |
