Fluke Biomedical - DPM1B
by Fluke Biomedical
Pneumatic Transducer Tester
The DPM1B Pneumatic Transducer Tester is an essential tool for biomedical engineers tasked with calibrating, repairing, and verifying the performance of medical devices that rely on accurate pressure measurements. Designed to handle both liquid and gas media, the DPM1B measures positive and negative pressure and can generate controlled pressures within a ±300 mmHg range—ideal for use in quality assurance and preventive maintenance programs.
Compact and reliable, the DPM1B supports applications in critical care, anesthesia, and diagnostic monitoring, providing the performance accuracy needed for compliance with clinical and regulatory standards. (Generated by AI)
-BradS
Wed Oct 14 2015
Difficulties in using DPM1B
Repeated difficulties in moving thumbwheel. Difficulties in setting desired pressure (e.g. 100 mmHg). Once it was reached the tester does not hold that pressure. Any troubleshooting suggestion would be much appreciated.
[list]              [*] Battery operated              [*] Generates and measures positive or negative pressures              [*] Operates with gas and liquid              [*] Troubleshooting with 1% accuracy              [/list]
Height1.5 in
Length 5.8 in
Weight10 oz
Analyzer/Simulator TypeGas Flow
Width3.6 in
