Fluke Biomedical - DPM4
by Fluke Biomedical
Parameter Tester
The DPM4 Parameter Tester is a compact, battery-powered diagnostic tool designed for biomedical engineers and clinical equipment technicians who need reliable and precise measurements during preventive maintenance or repairof medical devices. Lightweight and portable, the DPM4 is ideal for field service and bench testing.
Available in four models (1H, 1G, 2H, and 2G), the DPM4 offers accurate pressure, vacuum, and temperature measurements in base models (1H/1G), while advanced models (2H/2G) also provide gas flow, barometric pressure, and humidity readings. Replacing the discontinued DPM3, the DPM4-1G brings enhanced capability in a familiar format.
The intuitive menu-driven interface and 128x32 pixel graphical display make the device easy to navigate for quick setup and reliable data capture, helping ensure medical equipment is operating within safety standards. (Generated by AI)
[list]  [*] Palm size  [*] High accuracy  [*] Differential pressure, vacuum, and temperature measurements  [*] Multiple user-selectable units of measurement  [*] Simultaneous display of multiple parameter measurements  [*] Leak detection/leak-rate calculation  [*] RS232 for computer control  [*] Pressure measurements from -700 mmHg to +5000 mmHg range (applies to the 1G and 2G models only)  [*] Barometric-pressure, flow, and humidity measurements (applies to the 2G and 2H models only)  [/list]
Height156 mm
Length 34 mm
Weight0.4 kg
Analyzer/Simulator TypeGas Flow
Width94 mm
