Amvex - Digital and Analog Vacuum Regulator
Vacuum Regulator
Amvex® off ers a comprehensive line of Vacuum Regulators to help service your adult, pediatric, neonate and surgical populations. They are available in both Intermittent and Continuous models. Because our regulators have a technologically advanced design using modularity, your healthcare institution can easily upgrade models from Analog to Digital, and from Continuous to Intermittent. This modularity also provides for simple serviceability and maintenance. Amvexs patented Digital Regulators are fi rst of their kind in the market place. This technology provides the clinician higher gauge accuracy and large digital numbers for ease in pressure readings, as compared to an analog gauge.
1Reply10 years ago | Amvex Digital Vacuum Regulator Is there a procedure for calibrating the digital display for the Amvex vacuum regulator? Terry T Reply |
- Patented state of the art Digital Display Technology
- Digital eliminates moving parts, extending the life of the vacuum regulator
- Improved accuracy over analog. Accuracy is within +/- 1%
- Easy to read display
- Bars Represent Low, Medium, High and Full ranges
- Color coding range on digital display corresponds to an analog gauge
- 0 - 300 mmHg Gauge is standard offering
- Easy to upgrade to Intermittent or Digital right in the facility
- Same housing for both Continuous and Intermittent regulator
- Removable back plate and gasket for easy cleaning
- Reinforced inlet and outlet ports to prevent breakage
- Easily serviced and cleaned with cold sterilant
- Double O-Ring regulating module
