Fluke Biomedical - INCU Incubator Analyzer
by Fluke Biomedical
The INCU Incubator Analyzer is engineered to meet AAMI and IEC standards for neonatal equipment, measuring critical parameters such as airflow, temperature, humidity, and sound—all in one portable device. Designed for biomedical engineers and clinical technicians, the INCU ensures accurate performance testing of both closed convection incubators and open radiant warmers, including transportable and infant-controlled units. (Generated by AI)
Simultaneous Measurements: Monitor airflow, relative humidity, sound pressure levels, and four independent temperature points.
Standards-Compliant Testing: Built to support IEC 60601-2-19 and AAMI standards for neonatal incubators and warmers.
PC Integration & Automation: Operates in standalone mode or connects to a PC for automated testing, result logging, and test report generation.
Data Visualization: Use INCU software to configure tests, capture results, and generate full-color reports with charts and performance graphs.
Portable & Lightweight: Compact design allows it to fit inside incubators during testing for minimal disruption.
Optimize infant care equipment testing with the INCU analyzer—a trusted solution for reliable, standards-based performance verification in neonatal environments. (Generated by AI)
| Height | 5.5 in |
| Length | 10.6 in |
| Weight | 6.6 lbs |
| Analyzer/Simulator Type | Incubator |
| Width | 7.8 in |
