Fluke Biomedical - DALE301
by Fluke Biomedical
The DALE301 Rigid Endoscope Tester is a compact, easy-to-use tool designed for both technical and non-technical personnel to quickly assess the condition of most rigid endoscopes. Ideal for biomedical engineers, clinical engineers, and central sterile departments, the DALE301 enables fast diagnostics during incoming inspections, after user complaints, pre- and post-service checks, and routine preventive maintenance.
By streamlining endoscope evaluation, the DALE301 reduces equipment downtime, prevents unnecessary service costs, and ensures optimal performance of surgical imaging tools. (Generated by AI)
[list] [*] Incoming acceptance inspection performed [*] Simple to use [*] Lightweight and companct [*] No light source or other accessories required [*] Pre-repair inspections to prevent unneeded repairs and save money [*] Post-repair inspections to verify a performed service or indicate if a repair was simply a "dusting-off" [*] Compatible with most rigid endoscopes [*] Compatible with common cameras for hard copy documentation to trend test or to compare and decument service [/list]
| Analyzer/Simulator Type | Endoscope Tester |
