Puritan Bennett - 980
by Puritan Bennett
The Puritan Bennett™ 980 ventilator helps enable patients to breathe more naturally† through some of the most innovative breath delivery technology available. The simple, safe and smart design provides more natural ventilation that may help improve patient comfort.
1ReplyFri Oct 31 2025 | Low measured O2 We have a PB980 that keeps getting a "low measured O2%" error. We did a PM on it about a month ago and it passed the EST and SST, within a couple of days of the PM the respiratory department put in a work order saying they were getting the error. We checked it out and it will run fine in a test setting but as soon as they set it up for use it gets that error. I replaced the O2 cell again just to be sure it wasn't a bad O2 cell and then had them run it with a test lung, it ran fine. We re-ran the EST and SST, it passed both but as soon as they put it in patient use they started getting the low measured O2 error again. I am unsure on what else to look for that could be causing the error coming up? Any help is appreciated. Equipment: Puritan Bennett PB980 Reply |
1ReplyTue May 02 2023 | manual for neonatal I need the manual for neonatal and Pediatrics Please Equipment: Puritan Bennett 980 Reply |
1ReplySun Nov 22 2020 | Error KP0135 Hello, Anyone has experienced Error KP0135? The IFM board replaced, but the error remained. I really appreciate any help you can provide.Reply |
[list] [*] Simple - Their innovative user interface features a highly customizable display with intuitive screen navigation. [*] Safe - The newly designed Puritan Bennett™ 980 ventilator provides a unique ventilator assurance feature and an integrated expiratory filtration system. [*] Smart - Advanced synchrony tools help clinicians set the ventilator to adapt to their patients’ unique needs and help provide the appropriate level of support throughout the breath. [/list]
Medtronic (NYSE:MDT) is notifying customers worldwide of a voluntary field corrective action for its Puritan Bennett 980 (PB980) ventilator series.
Puritan Bennett 980 Ventilator Systems with software versions below 2.8 may have a software problem that causes the ventilator to stop working after the air and oxygen gas supply lines are disconnected and then reconnected.
A recall has been issued for the Nellcor Puritan Bennett, 980 Ventilator System. Part of the circuit board may have cracks due to problems in this manufacturing process. The cracks can cause the ventilator’s display screen to dim and give off a
