IDC - 1600 X-Series
by IDC
The 1600 X-Series is a complete system that delivers the highest resolution images without requiring the use of cassettes or unistrut.
The 1600 X-Series is a complete system that delivers the highest resolution images without requiring the use of cassettes or unistrut! Designed for all radiography environments, including outpatient clinics, imaging centers, private clinics and orthopaedic clinics.The X1600 provides a total solution for any of these locations -including cross table examinations. The 1600 is a complete DR solution with a floor mounted, multi-axis positioning device, attached X-ray tube, collimator and generator.
FORUMSView All (4)
-JWhitston
3 years ago
Software
Does anyone have or know of where I can get a software reinstallation CD for Megellan 3 or a newer version? It is for the IDC Xplorer 1600 or does anyone know if there is an alternate software you can use for it?Reply
3
-Michelle nc
8 years ago
IDCPARTS
Do you sell IDC parts
-Mirbeas
9 years ago
User Manual for Xplorer 1600 - IDC
Does anybody could share the User Manual of this system?
Thank you in advance.  Will    (mirbeas@outlook.com)
  • The 1600 is a complete DR solution with a floor mounted, multi-axis positioning device, attached X-ray tube, collimator and generator.
  • Like all IDC DR products, the 1600 offers high image quality all at a very affordable price: * 4.6 lp/mm * Proven CCD technology * 16 Megapixel * Digitized at 14 bits per pixel * Images in under 6 seconds * 5 year extended warranty, 3 year standard.
Choose the DR Technology: X4C IMAGING DETECTOR SPECIFICATIONS Detector Array :Full field, single VHD CCD Active Image Size: 43 cm x 43 cm (17” x 17”) Imaging Pixels :4,096 x 4,096 (16 Megapixel) Pixel Size: 108 microns Nyquist Resolution: 4.6 lp/mm Bit Depth :14 bit capture Fill Factor: 100% Preview Image :Approximately 5 seconds Processed Image Display: Approximately 10 seconds Imaging Detector Weight: 75 kg (165 lb) X3C IMAGING DETECTOR SPECIFICATIONS Detector Array: Full field, single VHD CCD Active Image Size: 43 cm x 43 cm (17” x 17”) Imaging Pixels: 3,072 x 3,072 (9 Megapixel) Pixel Size: 144 microns Nyquist Resolution: 3.4 lp/mm Bit Depth: 14 bit capture Fill Factor: 100% Preview Image: Approximately 5 seconds Processed Image Display: Approximately 10 seconds Imaging Detector Weight: 75 kg (165 lb) Standard System Features: U ARM STAND Maximum focal distance to floor: 167.5 cm (66") Minimum focal distance to floor: 48 cm (19") Rotation of the arm: 150º Detector angulation: 45º CCW and 25º CW Allowable table dimensions: H 57-86 cm (22.5” - 34”), W 70.5 cm (28”), L 216 cm (85”) • Variable source to image distance movement fully motorized with automatic stops at SID distances of 100 cm (40”) and 180 cm (72”) • Motorized vertical movement with automatic detent at the exact table top height, allowing fast and easy positioning for the table • Fully motorized rotating movement • Automatic stand positioning from table to chest positions • Intelligent anti-collision system X-RAY TUBE • Rotating Anode 12º High Speed • 150 kVp; 600 KHU • Dual Focal Spots: High Speed Small Focus 0.6 mm 40kW High Speed Large Focus 1.2 mm 80kW COLLIMATOR • Manual Collimator • Bucky Centering Light with Laser GRID Ratio: 13:1 Frequency: 70 lines/cm Type: Stationary, removable Focal Distance: 180 cm (72”) and 100 cm (40”) GENERATOR • 64kW, 640 mA • High Speed Rotor Controller • Automatic Exposure Control (3 field) TECHNOLOGIST WORKSTATION Each high speed computer configuration includes: • Magellan 3 Worklist software with TouchScreen compatibility • PureView - adaptive image processing algorithms • Flat panel monitor - 1600 x 1200 resolution • DICOM 3.0 functionality • Compatible with all major PACS - images can be in CR or DX format • VIPER - Visual Parameter Editor for image optimization • Intuitive AccuTech Exposure monitoring software POWER REQUIREMENTS 1600 Stand Dedicated: 230V10%, 20A, 55/60Hz Generator: 3ph. 380/480V Technologist Workstation: 110 – 250V, 10A, 50/60Hz OPTIONAL ACCESSORIES • Weight Bearing Stand • Orthopaedic Software • DICOM Worklist • Selectable Resolution (X4C only) • Patient Tables (Fixed, Mobile, Elevating or Float-Top)
