PCI Medical - G14TC-3
by PCI Medical
Ultrasonic Cleaner
The G14TC-3 comes with three tubes. Two tubes allow you to soak two TEE probes simultaneously in the high-level disinfectant. The third tube is for the initial water rinse which should be done at the system to protect you from off-gassing and drips. The special curved tubes on the TC model make it easy to insert and remove your long probes. The safety cage protects against damage to the tubes and probes.
-Zoe Gardiner
Sat Nov 30 2024
Education
My name is Zoe. I am in desperate need for education on our TEE cleaning procedures. Is there an Inservice or a video or just someone I can talk to about product G14TC? I work at Waldo County General Hospital in Belfast, Maine. My email is arielzoe2015@gmail.com. Thank you.
Equipment: G14TC
Height51 in
Length 16 in
Weight55 lbs
Width15 in
  • Number of probes soaked: 2
  • Face Velocity FPM: 50
  • Electrical (115V 50/60Hz): .5A
  • 2 Tubes for simultaneous soaking in high-level disinfectant
  • Water rinse tube protects you from off-gassing and drips
  • Curved tubes make it easy to insert and remove long probes
  • Safety cage protects against damage to the tubes and probes
  • Use with your choice of disinfectant (OPA, glutaraldehyde, hydrogen peroxide)
  • Minimum of 8 minutes to disinfect your probe
  • Made in the USA
