IDC - 1600 Plus X-Series
by IDC
Technologists can easily capture typically difficult images by positioning the stand, not the patient; providing multiple benefits.
The 1600 Plus is a complete DR solution with a floor mounted, multi-axis positioning device that also includes the tube and generator. With the additional features of a large LCD screen populated with patient information, arm-angle indicator, motorized collimator and remote control functions, this system is priced competitively with CR and is the most cost effective and efficient DR solution available in the industry!
0Replies8 years ago | IDC Xplorer 1600 plus. is there a shorter stepstool or bench so we can do standing feet Reply |
1Reply9 years ago | software update need to order drives for IDC 1600 Plus Digital Room SN# G-25056
Please send me a quote and availability.
Robin Beard Reply |
Online Storage Capacity | up to 2000 images |
Detector Type | Charge-coupled device (CCD) |
Pixel Matrix | 16 million pixels |
X-ray Generator Power Rating | 64 Kw |
Active Image Size: 43 cm x 43 cm (17” x 17”)
Imaging Pixels :4,096 x 4,096 (16 Megapixel)
Pixel Size: 108 microns
Nyquist Resolution: 4.6 lp/mm
Bit Depth :14 bit capture
Fill Factor: 100%
Preview Image:Approximately 5 seconds
Processed Image Display: Approximately 10 seconds
Imaging Detector Weight: 75 kg (165 lb)
