IDC - 2200 X-Series
by IDC
IDC provides the industry's first affordable dual detector DR system with the introduction of the 2200 X-Series. This solution is a traditional two receptor configuration that includes one detector integrated in a fixed, elevating, 4-way float-top table and a second detector on a vertical stand. This arrangement provides all the advantages of cassetteless DR while reducing the process and positioning adjustments that are sometimes necessary for single detector systems. Thanks to IDC’s patented passive trigger technology, the 2200 X-Series can be efficiently interfaced to existing X-ray generating equipment to reduce investment cost. Only IDC has high performance detector technology that is cost effective enough to provide an affordable two detector system.
1Reply14 years ago | IDC 2200 X-Series Does anyone have this system and if so how would you rate it?Reply |
[list] [*] 4.6 lp/mm [*] 16 Megapixel [*] Digitized at 14 bits per pixel [*] Images in under 6 seconds [*] 5 year extended warranty, 3 year standard [/list]
Online Storage Capacity | up to 2000 images |
Detector Type | Charge-coupled device (CCD) |
Pixel Matrix | 4,128 x 4,128, 16 Million pixel array pixels |
X-ray Generator Power Rating | 80 Kw |
Detector Array :Full field, single VHD CCD Active Image Size: 43 cm x 43 cm (17” x 17”) Imaging Pixels :4,096 x 4,096 (16 Megapixel) Pixel Size: 108 microns Nyquist Resolution: 4.6 lp/mm Bit Depth :14 bit capture Fill Factor: 100% Preview Image :Approximately 5 seconds Processed Image Display: Approximately 10 seconds Imaging Detector Weight: 75 kg (165 lb)
