Philips - Simply Go
Concentrator
Given SimplyGo's unique capabilities and design, you can also use it as a retail opportunity for your patients looking to purchase a portable oxygen system. And SimplyGo is appealing to referral sources as well.
FORUMSView All (8)
2Replies9 months ago | Runs for ,2min and shuts off Unit runs ,2min and shuts off Equipment: Simply go Reply |
5Repliesa year ago | Error message after approximately 10 min of run time. I have a SimplyGo that puts up an error icon (triangle) and beeps after approximately 10 minutes of use. The machine still operates but beeps with the warning. No other codes or information. I have taken it apart to take a look at the filter and it along with the rest of the machine is SUPER clean. It only has 500 hours of run time. Any ideas what may be wrong?Reply |
0Replies2 years ago | Battery shortage I cant source batteries anywhere in the uk. Van you helpReply |
- Ease inventory management
- Use less shelf space
- Reduce maintenance costs
- Minimize patient calls
Height | 11.5 in |
Length | 10 in |
Weight | 10 lbs |
Width | 6 in |
- Oxygen Concentrations: 86 to 97% at all settings
- Continuous flow settings: 0.5 LPM, 1 LPM, 1.5 LPM, 2 LPM
