Zoll - X Series
by Zoll
Defibrillator
At less than 12 pounds (6 kilograms), the X Series® is about half the size and half the weight of competitive full-featured monitor/defibrillatorsbut a lot more powerful. It's compact without any compromise in display size, capability, or performance. Designed specifically for EMS, the X Series offers everything you could ever want in an EMS device. And because its based on a platform developed for the military and air medical operations, the X Series rises to a new standard in ruggedness and durability.
2Replies2 months ago | CO2 Check Exhaust Flow End users getting " CO2 Check Exhaust Flow". Cannot replicate in shop. They noted it worked on the ground, but when in the air, helicopter, they would get the error. Any advice would be helpful. Thanks Equipment: zoll xseries Reply |
2Replies7 months ago | Zoll X Series / ProPaq Powering issues I’m troubleshooting a Propaq / X Series unit and could use some advice. The device shows the following symptoms:
I’ve checked the power being drawn from the power pack, and it’s coming through as expected (measured using a multimeter). However, once it connects to the main board, nothing powers on. Stripping out the front board looks like quite a task, and I wondered if anyone has encountered a similar issue before I proceed. I suspect a fuse on the front board may have blown, but before I potentially waste time on this, I’d appreciate it if someone could confirm or share their experience with a similar fault. Thanks in advance for any insights or guidance! Reply |
1Reply8 months ago | CO2 calibration CO2 calibration due keeps popping up. I can’t find anywhere in manual how to do this Equipment: Zoll XSeries defibrillator/monitor Reply |
Height | 10.4 cm |
Length | 8.9 cm |
Weight | 12 lbs |
Defibrillator Type | External, Automated (AED) |
Width | 7.9 cm |
